Dear Sir,
Thank you for great materials. But to be honest, I didn't understood it clearly in that movie about details in steps, in the field of mounting damper for adjustment. My questions are below.
1. Should we here operate mainly on lower collar (the bottom one), which operates only the ride height for the whole time, without adjusting spring collars?
2. For initial measurement for max. compression and max. extension (with searching of that "1/3" static ride height), should we at first, mount damper only with top mount, with disassembled spring & bumpstop, right? (Just like in case of measuring motion ratio from previous module)
3. After measuring min. and max. position, which allows us to calculate 1/3 rebound position, should we disassemble damper/-s, to mount on them again the rest of parts, like springs and bumpstops, reassemble it on the car, and then should we adjust final 1/3 static position?
I will be grateful for reply.
Kind Regards,
DL
