Duramax L5P -- RDS 64mm 9blade turbocharger
Fundamentos de fabricación para deportes de motor
1549 Vistas
Can anyone provide a quick rundown of where to start with tuning this turbocharger? What makes this turbo different than say a DuramaxTuner turbocharger I have done in the past?
Can't say, about the only comments seem to be it has less (turbine) back pressure, and will support "lightly" modified engines that can handle more airflow/boost.
As for actual hard data, that seems to be in short supply.
