Exhaust gas temperature probe
Fundamentos de la aerodinámica
Discusión y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
1444 Vistas
Hi this is Jay just asking Andre if their is a couple of manufacturers you know of that has a tool to measure exhaust gas temperature or should i use an infrared thermometer.
Check out Exhaust Gas Technology. They specialize in EGT probles, EGT amplifiers (so you can connect to your ECU or data logger), or complete instruments.
https://exhaustgas.com/
Thank you so much for the information.
