Ignition Dwell and ignition booster
Fundamentos de la aerodinámica
Discusión y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
1956 Vistas
is there a topic on how to optimize ignition dwell? and tuning a car with a ignition booster/voltage boost on the ignition coils.
What engine? What ECU? What is the ignition system? On any of the modern ignition systems (individual coil per cylinder) usually you just input the coil dwell information from the manufacturer and you are done. If the coils aren't powerful enough you buy aftermarket coils and then input the coil info into the ECU.
Ignition boosters are basically a 90s thing.
