Apexi boost solenoid settings
Fundamentos de la alineación de ruedas en los deportes de motor
2972 Vistas
Hi,
What is the output frequency and maximum & minimum duty cycles for Apexi boost solenoid?
I have picked the solenoid from Apexi Avc-r boost controller kit part number 420-a904.
Hello the solenoid can generally work between the range of 15-35hz and wil be ok from 0-100 percent duty cycle i generally use 20hz and find it will give nice smooth boost curve but i see others also get the same result with 30hz
Regards Ross
