Brake noise
Fundamentos de la alineación de ruedas en los deportes de motor
1547 Vistas
Hey, I got a problem that happens to many clients. After new suspension installed, when reverse gear rewarding the car, it happens always a noise like “ge-beng” when brake, it’s a problem of alignment or it’s a normal thing of the brake pads attached the sub bump? thank you very much
Hi Robin, I'm not sure I can help you on that one. Unless there's something thats actually been left loose on the suspension then I can't see anything that could explain the sound you're hearing.
Hey Andre, thank you the same. perhaps that i've installed SPLPARTS arms, the bushing ball joint is not a 90 degree as the install manual, but when i adjust the negative camber, the front lower joint ball point couldn't be a 90 degree, is that a problem. the front end link i fixed without any tension of front anti-roll bar.
