Course related resources
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: Análisis de la alineación en la vía > Qué ajustar
1644 Vistas
Hello, I am wondering if there is a section to view all the related resources for a course instead of having to search through each module to find them.
Also I'm looking at the alignment course cheat sheets on the "what to adjust" module. Am I going crazy or are the "YES" and "NO" parts of the flow chart reversed?
If you have oversteer mid corner, it asks "is the rear bottoming out" and if you follow "NO" it says to increase the rear spring rate, and if you are bottoming out, then it says to Soften the rear rate.
That would, indeed, seem to be the wrong way round, but I don't know the full context.
Cameron,
I see what you mean. I also noticed a few other things in the chart and let the team know. They'll be giving it a good look over and update as soon as possible.
Thanks for the heads up!
Hi Cameron, further to addressing those errors, we will have an internal chat about the possibility of a single resource location as you're correct, this does make sense.
Thanks
I didn't see these replies until now, as I just noticed you added a course materials section so I came back to this post to see if I missed any responses.
I see you guys were on it right away, Thank you!
