Gravel/Wet tires where to messure?
Fundamentos de la alineación de ruedas en los deportes de motor
1987 Vistas
Hi! I'm running an Suzuki Swift fwd in gravel rallys and tire pressure is something I would like to optimize. But when you are taking these measurements on the tyre you insert the tyre temp tool inside the tyre, but if I run these gravel tyres where would I insert it, between the "studs" or inside the groove? Since the studs is what is contacting the ground i assume that is where most of the heat will be generated but at the same time they will vary alot since they are so small. Here is a photo of what I'm refeering to. https://www.rallynuts.com/user/products/KUMR800R-2.jpg
Would i measure on the blocks themself or between the blocks?
Thanks!
Answered in another thread:
https://www.racecrafthq.com/forum/general-discussion/show/tyres
Matt
RaceCraft Team
