Laser leveling instrument
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: Ejemplos resueltos > Ejemplo práctico del Honda Integra > Paso 1: Configuración de los componentes de la suspensión
1880 Vistas
Where can I buy the laser leveling apparatus? What brand and model are you using?
We've used the Intercomp Laser Leveling System. Since this Worked example was created they've changed the Laser unit to a Bosch model but the use of the system is the same in practice.
