off road
Fundamentos de la alineación de ruedas en los deportes de motor
1131 Vistas
HI
If, on the contrary, thevehicle is raised. How would it affect the RC and CoG. How would this be corrected?
THANKS
With most suspension designs, the roll center will be raised with the ride height, and of course the Center of Gravity will go up as well. It is all part of the compromise in setting a vehicle up for off-road use. You will have less cornering capabilities.
