Rear traction rod for R32 skyline
Fundamentos de la alineación de ruedas en los deportes de motor
13090 Vistas
What does the traction rod do?
What will an adjustable traction rod correct on a lower vehicle.
Exactly which "rod" are you asking about?
Hi Basil,
It would help if you could provide a link or photo to what you're talking about. With a suspension like that in the rear of an early Skyline, normally when people use the term "traction rod" it is in reference to the amount of anti-squat the suspension has. Unfortunately, so many people and companies confuse the situation by using the same terminology to describe different parts, so it's best if you can give us a little more info 🙂
See attached diagram and picture.
I can see where the camber and toe are adjusted.
what does that arm(high lighted in the attachment) do?
The closest thing that i can think of is something similar to an arm triangluated 4 link suspension.
What effect does it have when that arm is lengthen or shorten?
  • R32-Traction-rod.pdf
If it works, this picture should clarify things ""
It appears to be one of the top links in a multi-link rear suspension, the toe is controlled by a separate linkage. Off hand, not sure what affect changing the length will have on the actual geometry, but it will alter the relative positions of both attachment points on the carrier as it will be moving though a different arc, and this will affect the design's intended movement, possibly improving it if the vehicle is lowered away from the OEM points.
Perhaps someone with experience with the vehicle, or the linkage characteristics can comment - it's a bit beyond me without a lot more investigation.
Hi Basil.
First thing about that link - it's simply one of the required links to properly constrain the upright, just part of the multi-link suspension. The two top arms in Gord's picture form a virtual top A arm. I've sketched in the equivalent A arm that these two arms roughly replicate.
Changing the link length you ask about would not make any significant changes apart from some camber change - certainly not over the relatively small changes you would be able to make to it. It would change the mechanical trail, but most of the effects would only change the force distribution inside the suspension arms rather than any meaningful handling changes (again assuming small changes in length)
The more meaningful change to this link would be to raise or lower the forward pivot point. This changes the anti-squat characteristic and is where the term "traction bar" (not very useful term!) comes from. Obviously, you can't change the height of the pivot by changing the length of the arm - this will require a different mounting point.
