The castor for the street use is uniform lift and right
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: Habilidades prácticas > Medición y ajuste de la rueda
889 Vistas
Caster
Usually, but if the roads in the area are quite steeply cambered - the middle is significantly higher than the sides - it's sometimes increased a little on the down-side (been quite a while, but I think it was that side) to help steer the vehicle against the natural tendency to turn down slope.
