Tire Pressures for Aligning
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: El proceso de alineación de 7 pasos de HPA > 2. Configuración del equipo de alineación
1507 Vistas
Hello, I was wondering if the tire pressures set when doing the alignment process should be the cold pressures or should i set the pressures to my target hot pressure?
Thanks!
If you know your hot presures, that would be the most accurate, in case the initial cold pressures have a noticeable delta as they warm up.
