toe adjustment by wheel or axle
Fundamentos de la alineación de ruedas en los deportes de motor
1729 Vistas
Hello ,
i have a e46 drift car and i have bought a wisefab kit.
On the wisefab site you can check individualy for your car the recomended alignment.
https://www.wisefab.com/fitment-calculator
Here sais the recomended toe number but it doesn't mention if this is by wheel or 2mm by axle ( 1mm per each wheel)
Do you what they mean or i should contact them?
Best regards
Oops, initially misread your question - it's normally the total (axle) toe in or out.
great , thank you.
