Vinyl tiles
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: Habilidades prácticas > Medición y ajuste de la inclinación
1140 Vistas
Hello, I would like to know where to purchase the vinyl tiles you use to level the car before doing a string alignment setup.
It's a flooring material. Do you have home improvement or hardware stores near you. It's typically sold in boxes to do some number of square meters. Looks like somewhere like Brico OK, Brico io or OBI would be a good start.
