Adjustable Launch control Rotary switch
1703 Vistas
Good day team,
I am wanting to put an Adjustable Rotary switch to control launch control RPM so i dont have to jump into the laptop every time track conditions change.
Is it as simple as wiring a rotary switch through an analogue voltage Output and setting up parameters in ecu?
Ecu is a Link G4 Plug and play (EVO 5)
Kind regards
It’d be an input and not an output.
they’re essentiallly a rotary pot and trim the 5v down as you rotate it and they just have detents built into the knob.
thanks peter,
yea sorry AN Volt input.
cool, that sounds simple enough
