DMC Af8 crimping tool
4805 Vistas
I purchased a:
Daniels AF8 Crimp Tool and
DMC TH163 M22520/1-04 Turret Head
is this compatible with the Deutsch DTM, DT an DTP series?
I am also looking at the autosport as series connectors and was wondering if this woiuld also work with them as well or do I need a different turret head or the AFM8?
Would anyone recommend any other turret heads for the AF8, and what terminals would you use it for ?
For Autosport with anything smaller than size 20 contacts you need an AFM8 with the correct positioners for the used contacts.
The AF8 can be used for Size 20 and larger, so DTM, DT and DTP as you intend to.
