Refresh vs Rebuild
3013 Vistas
What is the common understanding of the difference between an engine refresh and an engine rebuild?
Often a refresh is just a top-end (valves, rings ,or other particular items that might life out more frequently like chain tensioners). A rebuild usually involves complete disassembly, measuring and replacing all components out of spec, and reassembling.
For the detailed answer, talk specifics with the engine builder or supplier.
