Ring gaping
2018 Vistas
What is the purpose of the ring gap? Does it mandatory to have a space between
The ring gap is to allow space for the piston ring to expand due to heat. It is mandatory to have space in between. There should be a specification for the engine's gap (certain number of mm range).
Hey Fayad, we have a webinar on this subject here: 149 | Piston Ring Gap - How it Destroys Engines
As a Gold member you can access this with no extra cost.
