How the ring lands prevent detonation and flame travel?? How does it worK
Hi Johnny
Ring lands do not by themselves prevent detonation they merely support the ring in the piston while the piston ring travels up and down the bore sealing compression above it and controlling oil from passing the piston into the compression area, the ring land can suffer from detonation damage caused by a poor flame front and detonation or pre-ignition,
this intern will stop the rings from doing there job
Regards Ross
Thank you so much for the explanation....pretty clear!
