Translate
Módulo relevante: Anatomía del motor > Bloque de motor
1419 Vistas
Hey there Hope you're well .. I'm facing a problem with translation from English to Arabic.. is there any chance that I can see this video with Arabic translation and thank you a lot .. I'm enjoying watching and hope I will get a lot of experience and knowledge
Hi, Hassan. Although getting information in your own language is very convenient I would suggest you keep trying to get it in English. The reason being is that there is a huge volume of information out there related to tuning and it's all mostly in English. You can get tons of usable info if you don't just limit yourself - it's harder of course but more beneficial at the end of the day.
As Shota said, "english" seem to be the default language in motorsport, as in many things, with French and Spanish also being common.
If you continue to study the language, and its use, you will have many other resources you can use AND if you continue in the field, or any other where "english" is commonly used, you will have a BIG advantage over those who don't understand, or have a limited ability.
In the meantime, there are several members who are Arabic, or who understand the language, and they may be able to help you with the harder parts if you address them in your native language? Shota has done this with some of the Russian folks in the past.
