Plumbing waste gate
Fundamentos de la fabricación en el automovilismo
Debate y preguntas relacionadas con el curso Fundamentos de la fabricación en el automovilismo.
5478 Vistas
What's the right way for plumbing waste gate pipe to boost selonide valve.
please provide specific details. What vehicle and engine do you have, what ECU do you have, is this being controlled by the ECU or by an external controller, is it an internal or external wastegate, does it have 1 turbo or 2 (parallel or sequential?), is it a typical 3 port wastegate solenoid or is it something else (OEM style 2 port or a stepper motor or...)?
its ABA-FD2 honda civic Type R k20a its NA car and doing after market PRL turbo kit percussion waste gate and 4 port hondata selonide valve ecu is m150 motec single turbo garret gtx3076r gen2
Hi Faisal, the recommended technique of plumbing a 4 port solenoid to an external wastegate is shown below:
