gas lens and cups
Soldadura TIG práctica
Discusión y preguntas relacionadas con el curso de Soldadura TIG Práctica.
1636 Vistas
What length is prescribed in general for tungsten? what starting point meaning for a #5 cup or lens how long should the tungsten be? I understand that the larger the lens the longer the tungsten can be but what is the average starting point for tungsten length?
General rule i have used is stick out should be the diameter of the cup being used. Although on really large gas lense cups i have had success using even more stick out to get proper gas coverage in tight spots
