Hondata kpro bad idle surge when warm help
Soldadura TIG práctica
Debate y preguntas relacionadas con el curso de Soldadura TIG Práctica.
2306 Vistas
the engine starts up fine and idles right around 1.0 lambda I was starting to do steady state tuning and I noticed when I come to a stop after car is warm the idle will surge badly from about 900-1400 rpms I tried smoothing the ignition maps no difference I tried adding or subtracting some fuel from the cells it was doing it in I’m going to attach the file I’m having a issue getting the log file to link to this but I’m going crazy trying to figure out please help
it won’t let me attach the log because it’s a kdl file if you know another way to upload it that would be awesome aswell
Can you zip the log file and upload that please?
Thank you I linked it above I had to make the log alittle shorter aswell
