Why does my manifold pressure read higher than my pre-throttle boost pressure?
Fundamentos de los compuestos en los deportes de motor
Discusión y preguntas relacionadas con el curso Fundamentos de compuestos en deportes de motor
1433 Vistas
Body:Hi everyone,I have a question about a pressure reading issue on my turbo car.
My setup is:
Boost pressure sensor is installed before the throttle body (pre-throttle)
MAP sensor is in the intake manifold
Sometimes the manifold pressure (MAP) shows a higher value than the boost pressure sensor
This happens mainly during partial throttle or transient conditions
Under WOT, both values get closer, but MAP still sometimes spikes higher
I would like to understand whether this behavior is normal, or if it indicates a sensor/scale/configuration issue.
My thoughts so far:
Pressure drop across the throttle plate during partial throttle
MAP reacting faster to engine demand and pulsation
Exhaust backpressure (EMP) causing reverse pressure waves during valve overlap
Pre-throttle boost sensor responding slower due to hose length or placement
Possible calibration/scaling difference between the two sensors
Absolute vs gauge pressure mismatch?
Questions:
Is it normal for MAP (post-throttle) to spike higher than pre-throttle boost under certain conditions?
How do you normally diagnose this in MoTeC / Haltech / Hondata logs?
At WOT, should pre-throttle boost always be higher than MAP?
Could high exhaust backpressure (EMP) cause MAP to exceed pre-throttle boost momentarily?
What’s the typical pressure behavior you see in your logs?
If needed, I can upload some log screenshots (MAP, Boost, TPS, RPM, IGN, Lambda).
Any insight from people who have dealt with this would be greatly appreciated.Thanks!
It could well be pressure wave harmonics in intake system when air charge gets reflected from closed intake valves and goes back to intake plenum which has bigger inside diameter resulting in lower air velocity but higher pressure. It can be just one or the reasons among all others you named...
Is it the same story if you switch places between pressure sensors?
I'm making an assumption based on your screenshot that you're using a MoTeC M1 with a GP based firmware.
The behavour you're seeing is caused by Inlet Manifold Correction. Check the help on this it's pretty extensive.
