Debate y preguntas relacionadas con el curso Fundamentos de los materiales compuestos en el automovilismo.
Hi,
I seem to be having difficulty getting TXL wire in the UK - this a good alternative?
https://uk.rs-online.com/mobile/p/automotive-wire/3694800/
Thanks
Rob
G'day Rob.
Yeap, that looks like a good alternative for sure. Check out the price of M22759/32 wire though, as in the UK (The home of motorsport!) you should be able to find a supplier, and the price might be pretty comparable to the link you've got there.
Check out IS Motorsports.
As per Zac's comment, you can get M22759 at a pretty good price - you need to check out the Harsh Environment section of RS - https://uk.rs-online.com/web/p/harsh-environment-wire/1135821/ depending on gauges you may even find it cheaper than TXL
Hi Guys, did anyone find a good alternative in the UK? The automotive wiring available from RS Components has a minimum size of 0.5mm2 and most of the harsh environment wire only comes in one or two colours.
Any help would be greatly appreciated!
Steven
