Asffect of AF
Fundamentos del ajuste del diésel
Módulo relevante: Fundamentos del diésel > Efecto del AFR sobre la potencia y el par
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
1134 Vistas
Why does a lower AF ratio result in higher power but not result in more boost pressure?
I used to run turbo engine without any boost control and bigger power always resulted in higher boost. Once you introduce any mean of boost control your boost level is limited as per settings...
