Heat vs Timing
Fundamentos del ajuste del diésel
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
1594 Vistas
In module "effect och ignition timing on EGT" you show that egt goes higher when timing is retarded. But in the module about emission, you mention that its common to retard timing for lower temp.
Maybe EGT is up and temp in combustion chamber went down?
hello, EGt goes up and water temp goes up with retarded timing. but over mbt the opposite effect takes place
Regards Ross
