Mr Hernandez
Fundamentos del ajuste del diésel
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
1503 Vistas
1- Could you send our certification?
2- How I can calculate injection pulse on Pilot Injection and main injection, on a Diesel Engine 1KD, how short or long It can be for injection inside the hole of the piston?
3- Do you have a course of use ECM Titanium, HP Tuners, Winols, Swiftect, BitEdit??
4- How I can calculate Fuel Pressure, Injection Timming and pulse with if I change the injector nozzle? I hear in the course i think you cannot go over 20% - 25% of bigger holes.
5- What happens if I change 155 degress angle on the injector nozzle by 152 or 150 degress angle, It can have better response, torque, etc??
6- What happens if I delete the electronic Throttle on the 1KD engine: it can have better response, more power, less heat, etc??
We appreciate your help.
