SOI
Fundamentos del ajuste del diésel
Módulo relevante: Fundamentos del diésel > Sincronización de la inyección
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
1261 Vistas
Hello. Im correct calibrations for tuning Audi A6 C8 3.0TDI 286hp
For example at Stock, we have SOI Map at 4000rpm
60 mg/str 18 degree
70 mg/str 18 degree
80 mg/str 18 degree
Its optimal SOI, but it is compromise between NOX ?
Stock 80mg/str max Stage1 we have 94 mg/str max
How can Im correct maps SOI for 94mg/str?
Only dyno ans tests but theoretical calculation ?
Theoretical calculation add me 1-2 degree add for optimal SOI, if stock SOI is optimal.
Thank you )
uppp
