Example Logged Data and Software Tools Download
4341 Vistas
Hey Team!
The Professional Motorsport Data Analysis Course uses 3 different data systems for the demonstrations throughout the course: Bosch WinDarab, Pi Toolbox and MoTeC I2. As I say in the course, you'll get much more out of the material if you can have a data system open as you move through the course so you can practice the techniques as you go. It really does not matter what logged data system you are working with, the concepts apply regardless. You will inevitably find you gravitate towards one of these systems more than the others, but I encourage you to put the time into playing with them all at least.
We have made available some logged data in all 3 of the systems we use in the course. This means if you don't have any logged data of your own yet, or you are curious about trying out different systems you can download the data for yourself and play around.
I've also included links to the analysis software you need to analyse each of the different data sets. Hopefully, these links to each of the manufacturer's websites remain working (we have no control over this) but I'll update them over time if need be.
If you aren't familiar with the system you want to use I recommend reading the relevant help file and having a look at some tutorials. If anyone has problems accessing the data please post to the forum and we will find a fix for you! Otherwise, enjoy guys 👊 - Tim
Bosch WinDarab
Example logged data - Data is from a GT car at two different circuits
Analysis software download
Scroll down to the bottom of the page, click the "Downloads" tab, download "WinDarab 64 bit" from the Software section.
Pi Toolbox
Example logged data - Data is from 2 different touring cars and drivers
Scroll to the bottom of the page, download the latest version of Pi Toolbox.
MoTeC I2
Example logged data - Data is from a GT car with 2 different drivers
Scroll down to the Data Analysis section and choose either MoTeC I2 Standard or Pro. Note that only data recorded by the logger as "Pro" can be opened in I2 Pro, "Standard" data is not able to be opened in I2 Pro without an additional software license upgrade. The data supplied from the course resources section is Pro data, so either the Standard or the Pro versions of the software can be used with this data. The Pro version of I2 has more features which makes it more powerful than the Standard version.
Hi Tim,
The Pi and i2 example logged data links are swapped.
Thanks Stephen, updated now 🙌
