96 Legacy GT Wiring
Fundamentos del cableado EFI
830 Vistas
Hey Guys,
I've got a 96 Legacy GT originally came as a twin turbo set up. Vehicle was stripped out when we received it. Have got a donor motor with running gear from a 98 Impreza GC8 which is a single turbo. Have got the OEM ECU for the GC8 with partial harness and also have a link monsoon wire in which came with the car but hasn't been wired yet.
How do i go on about getting the vehicle wired up. Getting the engine components to light's fuel, ac/heating components to work. Do i use the OEM ecu with partial harness and build from that or do I use the monsoon and start from scratch?
