Don't know where the install the air intake temperature sensor installing a fueltech 600 EFI system don't know where to put it normally it would be put inside the pipe running to the throttle body but we're not running a scoop or a pipe any suggestions would be greatly appreciated
Add a pipe to the front of the car, then mount the sensor in the pipe (you know it's the right thing to do). Otherwise, just put it anywhere in the engine bay, near the throttle body since that will be the air that makes it's way into the intake. If you expect the car to breath from the cowl area, then mount the sensor there.
The closer you can get it to the intake ports the better. You don't have a plenum in that setup so you are making it difficult. Those EZ EFI kits typically have a mounting point in the throttlebody.
