Audi AAn Engine on EMU Black
Fundamentos del cableado EFI
1040 Vistas
Hi guys, anyone can help with the pinout on the engine triggers?? This engine has 2 Vr sensors 3 pin on the crank and one hall sensor also 3 pin on cam. Im using pin 1 sensor grd, 2 signal, 3 Shild on the vr and on the hall 1 sensor grd 2 signal 3 12v supply. i can not read signal on scope mode in the ECU. Can anyone give a help?? Thank You.
