Back again looking for pins
Fundamentos del cableado EFI
1935 Vistas
does anyone know where I can buy these terminals, please ?
They look like variants of the common spade (AKA blade) terminal. they're available in a staggering number of variations - https://nz.rs-online.com/web/c/connectors/wire-terminals-splices/spade-connectors/?pn=1&searchTerm=spade+terminals - the usual size is 6.3/6.35mm wide, with narrower and bigger versions. Measure the width of the male and it may be ~4.8 or 3.2mm, which will narrow things down.
If you're replacing a male/female pair, there are other options available that may handle more current without overheating like that.
Oh, any automotive supplier should have them, or something to do the job - auto' sparkies certainly should. Check the yellow pages (if they're still a thing) for your area, or have a look on-line for a place near you.
it is of an ICE Ignition I have plugs but no pins I have rang them they will sell me plugs with pins but not pins alone want to keep the same plug
I was after about 30/40 of each I like spares
https://www.corsa-technic.com/item.php?item_id=1113&category_id=111
https://www.corsa-technic.com/item.php?item_id=1112&category_id=234
I'm like 90% sure this is it. Perhaps you can find from a more local distributor? If not they ship internationally
Thanks, Teeson111
I think you are right I have ordered 100 of each everybody here that I have found wants me to buy the plug as a kit
Thanks again
