Bosch Accelerator Pedal Wiring Pinout
Fundamentos del cableado EFI
7661 Vistas
Hey Guys, just wanted to check if I’ve got the pinout correct for the Bosch Accelerator Pedal Sensor going to a Haltech Elite 1500
1=+5V
2=+5V
3= Sensor Ground
4= APP 1
5= Sensor Ground
6= APP 2
What you've describe should work given the data sheet provided. I would expect APP 1 & APP 2 to read opposite to each other (one goes up with increasing pedal position, while one goes down), but you'll have to test to see what you get.
