Calculating Fuel Sender Voltages
Fundamentos del cableado EFI
5542 Vistas
My electrical maths is a bit foggy.
I have a 0-90ohm fuel sender in an 80 litre tank which I tested so I have the actual sender resistances for each 5 litres of fuel from empty to full. e.g 89.8 ohms @ 80 litres, 76.8ohms @ 75 lites, etc.
The sender is wired into a Plex SDM700 dash analog input which requires a 0 to 5v signal so the pullup resistor option selected. The pull resistor, according to the documentation is a 1K resistor.
How do I calculate the voltage output from the sender for each of my resistance points so I can use them to properly calibrate the input table?
The formula for a voltage divider is this:
Voltage = Reference Voltage x (sensor resistance / total resistance).
The total resistance will be the pullup value (1000 ohms) plus your sensor resistance.
So if the pullup is to a 5V source, the formula will be:
Voltage = 5 x (resistance / (1000+resistance)).
Voltage @89 litres = 5 x (89.9/1089.9) = 5 x 0.0825 = 0.412v
Voltage @75 litres = 5 x (76.8/1076.8) = 5 x 0.0713 = 0.356v
This online calculator is nice and easy to use:
Voltage Divider Calculator (ohmslawcalculator.com)
Thanks!
