Connector PIN identification
Fundamentos del cableado EFI
5088 Vistas
Hi All,
I'm trying to confirm the pins used in the below connectors.
https://performanceparts.ford.com/download/instructionsheets/FORDINSTSHTM-6017-A504VB.PDF
M C175T 50-way transmission pocket
N C175B 70-way cowl pocket
Shift Light Install-Mustang 2011-2013 5.0/5.4L V8
https://www.te.com/usa-en/product-1438136-1.html
I think it's the
https://www.te.com/usa-en/product-CAT-G3353-T273.html?r=0&compatible=5-1438129-9
system, but I don't want to order a bunch of stuff unnecessarily.
Thanks in advance!
Could you post some more information on what the problem seems to be and/or what you're trying to do? It's late here, but even so it's hard to tell?
Hey Gord,
The connectors are part of a ford racing loom that goes with the 5.0 Coyote Engine (create motor with a Tremec transmission). We fitting to a right-hand drive Cobra replica and we may need to reroute the injector (and other sensor cables) due to the pedal foot box moving left to right.
I want to have some spare pins to have so I can customise the loom. My preference is to create a whole new sub-loom rather than splice the existing one.
