Crimper for LSU 4.9 terminals
Fundamentos del cableado EFI
1440 Vistas
Does anyone know whether these crimpers would be suitable for the terminals on an LSU 4.9 connector?
https://www.amazon.com/IWISS-Terminal-0-1-1mm%C2%B2-Amphenol-Connectors/dp/B08D67L3YS?th=1
The terminals look like this:
https://racespeconline.com/products/honda-connector-7
Thanks!
Hello Richard,
I use the Rennsteig 624 663 3 02 RT die set in the Rennsteig PEW12 frame. This is the tool specified for those contacts so it does an exceptional crimp.
A cheaper alternative is the Sargent 1026CT which can be used to get acceptable results. It does require a bit of testing to see what size die to use. With 20-22AWG M22759/32, die E for the conductors & die A for the wire seal work alright.
