ecu grounding
Fundamentos del cableado EFI
Módulo relevante: Diseño del arnés de cableado EFI > Conexión a tierra de energía > Caminos comunes
1070 Vistas
so if we ground the ecu to the just the block or just the battery, it is safe from it being destroyed if starter ground wire is faulty?
