Efi loom
Fundamentos del cableado EFI
1874 Vistas
Hi can a standard efi loom be cut and soldered back together to make the loom smaller
Did you mean "cut and crimped" ? I'm on the side of never soldering a connection on an automotive loom.
And in answer to your question - if a new installation allows it, why not reduce the length/size of the loom.
