EVO X Jumper Plugs
Fundamentos del cableado EFI
2195 Vistas
Does anyone know where I can purchase an Evo X ECU plugs. I am looking for the plugs that connect to the ECU. I will be using it for ECU unbricking. Currently I am using pins and having to slide each pin on to the ECU one at a time, this is very time consuming.
Hi
I'm looking for them too. Looks quite difficult to find them. Have you found a solution?
