Fuel pump wiring and plugs
Fundamentos del cableado EFI
1913 Vistas
i know Zac mentioned he uses 14AWG wiring for fuel pumps, but what connectors are best to use?
For 14AWG I think Deutsch DTP connectors are the likely option but any opinions appreciated.
TBH I’m trying to avoid buying yet another crimp tool for just this one plug, any other options folks use therefore considered!
Cheers,
Mark
So I bit the bullet and ordered the Tool Aid Master Terminal Service kit, along with a bunch of DTM and DTP connectors! Expensive but should see me right for years to come :-)
G'day Mark. You've made the right call :-). I use DTP connectors for fuel pumps often (not in-tank connections though!) and they are perfect for the application.
