FUELTECH 550 HARNESS TO S2000 CKP PINOUT
Fundamentos del cableado EFI
501 Vistas
I'm wiring myself a 2005 s2000 with a Fueltech 550, i have a doubt with the CKP pinout. The oem manual says that terminal #1 is sensor ground, terminal #2 is sensor output and terminal #3 is ground (G101=acronym used in Honda) ((picture attached)). Searching in the web there's not information about f22c engine than lead me to know where in the fueltech wiring im going to connect each one. In harness A wires 18 and 19.
