Help identifying terminal on Subaru
Fundamentos del cableado EFI
2211 Vistas
Can anyone identify the terminal in the pic below. It is for a Subaru DBW pedal plug, but it’s also the same as the terminals for the DBW Throttle body plug and it’s also the same as the terminal on the 01-07 wrx/forester AFM as well.
im wanting to make up a loom without any splicing etc
From my research so far it may be Sumitomo?
After all my searching for terminals, I remembered seeing something like this on ebay uk!
You'll need to measure yours but these look pretty similar...
https://www.ebay.co.uk/itm/F-050-electrical-electronic-terminal-Sumitomo-Toyota-replacement-repair-wiring/292643464479?hash=item4422e8e51f:g:6AgAAOSwGz9ar-w4
Can you pop up a picture of the connector housing body aswell Daniel? I usually find them easier to recognise that way as opposed to just the pins :-).
