Honda Map sensor
Fundamentos del cableado EFI
2332 Vistas
My map sensor has 3 wires ground, 5v and signal. Would signal be wired to an output or input pin to the ecu, I am assuming input?
The signal from a MAP sensor, is wired to an input to the ECU.
