Identifying these OEM Connectors and pins
Fundamentos del cableado EFI
2489 Vistas
Hey all,
Im hoping somebody can help me identify these Connectors and pins, they are from a Nissan R34 Skyline.
No doubt they are quite common and i have tried to search but trying to find even the correct pins on the internet is becoming quite overwhelming..
(I did read somewhere they are made by nippon denso but could be wrong?)
The first 4 pin plug is for the Headlights, i also require the pins for this plug.
The second plug is for the Refrigerant pressure sensor - i only need pins for this.
Parker light plug
And also terminals to suit mini fuse, fuseable link and also relay bases, i imagine these are quite universal but not sure if i have measured them incorrectly or am searching the wrong keywords.
Cheers,
Have you tried contacting someone like these guys who have the Nissan EFI connectors:
https://www.efihardware.com/products/c340/Nissan-Fuel-Connectors
I'd get in touch with Ballenger Motorsports too, their supply of OEM connectors is pretty impressive. I'm more versed in the EFI connectors, not the body connectors unfortunately.
