LSU sensor without resistor like Haltech and Daytona Sensor why?
Fundamentos del cableado EFI
1415 Vistas
Hi, on Haltech and Daytona sensor wideband, they change the LSU sensor connector for Deutsch DT.
When I check the wiring the resistor don't seem to be use. Why?
https://i.ebayimg.com/images/g/8yMAAOSwBzpblqJ1/s-l640.jpg
thanks a all infos
Because they use free-air calibration instead of the built-in calibration resistor. Easier and cheaper for them. Not as convenient for you.
