Main battery breaker(kill switch). Golf mk5
Fundamentos del cableado EFI
548 Vistas
Hi I'm building Golf mk5 autocross car for my 13yo daughter. And the challenge is how to wire up the main battery breaker correctly.
I found out I need a breaker with three contact set. As a single contact set just prevent it from starting but would not kill the engine when its already running. (As it should do according to the regulations here in Norway ).
But which wire should I put on the other set?
Using original ECU.
Has anyone done this on a Golf Mk 5 or other VAG product.
I have found this description and diagram useful:
https://www.pegasusautoracing.com/document.asp?DocID=TECH00109
