Maxxecu sport . Audi 2.8 30v , v6
Fundamentos del cableado EFI
516 Vistas
Hej. Started to plan wiring harness for audi a4 b5 1996, 2.8 30v (V6). For now just cant wrap my head around and clearly understand how to wire up both intake cams and vvt°s, Originally it has 2 cam sensors an 2VVT solenoids( one on each intake cam). As far I could find information solenoids works only like on|off in some range of rpms. My plan is to wire BANK1 home|cam . Thinking if its possible to wire and control both VVT solenoids from one ECU output?
Second. Found some info that its needed to wire BANK2 cam sensor to Digital input, to be able to see if VVT solenoids is working correctly. Can someone explain me if Im right or not?
Thanks in advance .
